Hi
I put a CY engine in my 1982 passat 2-door.
I changed the gearbox from 3M to 2N, so the ratios are better for a lighter car Can I keep the same speedometer in the car? Will it show the actual speed, or will it be different??
ergo: Is a 1800 speedo different from a D/TD speedo?
3M to 2N gearbox?
3M to 2N gearbox?
Re: 3M to 2N gearbox?
No,all 4 Cylinder Front wheel drive have the same speedo.Zollie hat geschrieben:ergo: Is a 1800 speedo different from a D/TD speedo?
Only 5 Cylinder and syncros have a different speedo.
Greetings
